I have a 2004 sonata and I'm trying to figure out if my switch, blower motor, or relay is the problem. When I turn switch on to 1 the a/c light comes on, the a/c kicks on and I can feel cold air coming thru my vents. When I turn switch on to 2, 3, or 4 no air comes out. I'm thinking it might be the switch. If any of the members here have had this problem and a fix please share this with me. No use replacing items when they are not bad. Thanks!
You might be right. You'd really need to test it to know for sure.
There is usually no need to remove the AC control panel to check the switch. You can check it at the speed control resistor behind the glovebox....
441059
