I’ve had this Hyundai Santa Fe for a few years now and it’s been a great car, up until the last couple months. This started with a hot issue, where the car would start to kick and buck under load at operating temp. After letting the car cool down for a couple hours, it would restart and run normal until back at operating temp.
That issue got progressively worse, rapidly. And it wouldn’t start anymore. Starting with fuel I checked fuel pressure, and had 38 psi at the pump, went ahead and replaced the in tank fuel filter. This got me to where it would run and die after 3-4 seconds. This continued for a couple weeks until it wouldn’t start anymore again. Checked for spark and had none. After some reading on here determined it was a cps/cks issue. Borrowed a buddies code reader, and had a stored and pending code both for ckp. Replaced both cam and crank sensors. Still no spark, checked for voltage at the coil and found none, so for diag purposes, wired a ign on hot wire to the power feed on the coils, got spark back but still no fire. Replaced the plugs, and drained the fuel through the return line at the rail and out fresh in. Put my meter on the injector harness plugs, and have battery voltage on both leads, but neither break when cranking. Pulled the rail and injectors to confirm. All 4 injectors dry. So after some more reading, found that if the tps was no good, injectors could die like this, as with the ignition failure circuit. Seeing as I had no voltage at the coil, I went ahead and replaced the ignition failure sensor, and regained spark in the factory form(without a jumper) At this point I still have no injector pulse, but have spark, **** some starting fluid in the tb, and started the car, she fired up, but the tach is dead. Am I missing something obvious? I’ve read that without rpm the injectors won’t fire. Tps voltage measures .33v at closed throttle, and 4.26 at wot.
