Does the motor make any sound when you try to close it using the switch? If not it might be a good idea to check the fuses, if you haven't already, before you start stripping parts off to manually close it.
Reflowing/resoldering the joints inside the relay helped me with this. I had intermittent operation of the close function of both close switches. Replacing the limit switches on the sunroof motor themselves didn't seem to make a difference.
As for manually closing it, there's a page in the manual that shows how to close it.
