I drive an 04 Elantra GLS and I’m looking to put a turbo in it. I was wondering what kind of boost and horsepower the stock engine can SAFELY handle (stock internals, block ect.) also if someone has a link to a forged/upgraded internals rebuild kit, that would be nice.
Second, I’m looking to put a 6-speed manual in it and I’m not too sure where to start looking. I doubt there’s a plug and play option but I am able to rebuild if there’s 6-speed internals that fit the case. Any advise, links or options would be great.
I plan on using this as a fun daily. I dont need 600 hp but I want a bit more than the 100ish I’m getting now. I believe the stock hp is about 135 at sea level but I live in Denver and can really feel the elevation.
Why not just buy a vehicle that is what you hope to achieve. I don't think you are going to like doing this transformation.
00000732
Best practices for requesting help:If you haven't done so fill in your vehicle info and profile page. At upper right corner under the search box click on user cp (it's your control panel)
This info will show up to the left under your user name and is very helpful.
  • Be sure you are in the correct forum for your vehicle.
  • Do a search for your problem. A lot of stuff has been asked and answered.
  • Do not double post for the same problem.
  • Give the model year....Engine size...transmission type (auto or standard)
  • Take a single issue at a time. Posting multiple issues at once will get convoluted very quickly
  • VIN number can be very helpful
  • Vehicle history can be good. How many miles. If not bought new, how many have you put on it.
  • Describe the problem best you can. If a noise can you get a sound or video file
  • Tell us what has been done, if anything, thus far. If tests have been performed give actual results not OK or passed. If scanned for codes the actual code(s) not O2 sensor or MAF, Etc.
  • If the vehicle has been to a repair facility it would be nice if you could post a picture of that invoice/bill
  • If your vehicle is under warranty you should have the dealer check it out. If it's a problem they see many times they will generate a safety recall of TSB. This is how they know of the problem.
Thanks,
Welcome aboard.
