Hi All, First post so be gentle!
I've got a 2004 2.0 CRDI Santa Fe (which I've had from new) and I've noticed it being a bit 'jerky' whilst driving recently ... spotted that when the AC is on at idle the revs drop by a couple of hundred then every few seconds they return to normal.... tested with higher revs (c2000) and can see the same happening, this appears to be happening whilst driving (only when AC is on) .... AC was recently leak checked & regassed....Any ideas?
What you are seeing is the load the compressor in the AC is putting on the AC system when it is turning on and off. Idle goes down when it turns on and goes up when it turns off.
I might see if I can get a little oil added to it.... see if it makes a difference; I was hoping to avoid replacing the compressor £££ v value of car!!!.. thanks for your advice Johnaauld.... It's been a dream to own, only consumable parts, a clutch and a wheel bearing in 14yrs.
