I have a 2003 Hyundai Sonata and when I try to use the trunk latch on the remote the trunk refuses to open. However, if
I use the key the trunk opens fine. I think this is a truck acutator issue, but is there a cheaper way to fix it?
If the actuator is bad the only cheaper option is to use your key.
There is also a lock on the inside of your trunk that prevents the trunk from being opened. It is a small sliding lever that may have moved if rubbed against an item in the trunk. Open the trunk and move lever to opposite position and test your luck.
