Hello members,
Please help me to sort of these issues on my sonata, It is not starting, i have changed the fuel pump and clean the tank, also crank sensor as well. My mechanic says, pulse is not generating to fire up. Please help me to run the car.
Looking forward for your help.
Have you checked anything else? Battery? Alternator? Starter? Ignition? Is there any noise when attempting to crank? Do the accessories come on in the car when you turn the key? Have you managed to isolate the problem to a specific area, i.e. fuel delivery? When was the last time the spark plugs, wires, and boots were changed?
I assume what you mean by "pulse not generated" you mean a pulse to actuate the fuel injectors and not pulse to actuate spark plugs. That would be a cam sensor problem, not a crank sensor.
