What is we doing back there.. got pic of offending nut ?
Right hand thread,, you do have the electric coupling off front of diff housing ...
Un-stake the nut first
Fill spring side of seal with grease to keep spring from popping out when seal tapped into place, put a wipe of grease on seal lip in the center between the 2 edge of seal lip
Here is a picture of the nut-. drive shaft off and no locking stake. I even used a three tonne jack on an extension bare and actually lifted the back end off the ground. passenger side rear. Locked differential flange with locking tool as well.
