Anyone know of anything wrong with the 2003 Santa Fe transmission?
Mine has about 9000 miles on it and it keeps slipping. Not sure what's going on with it.
I've felt when drivng the santa fe, that it has hesitation both upshifting, and especially downshifting. Also, the car is just over 33,000.. and shortly will be on its SIXTH set of brakes. The first went around 6k, then we had ones put on at a private garage, which lasted till 15k, then the rest put on from a Hyundai Dealer. That went at 20k, 26k and now 33k.
i think i was having bad luck with mine........
[snapback]507[/snapback]​
I had the same problem just take it to the dealer for there is a recall on sensors and they will want to change your fluids but only do it once they will want to change it everytime you have oil change. There are about 20 recall or maintenance messages on the trans alone. Good Luck!
