Been working on this since I got it 2 yrs ago. Going nuts now with it cranking but not starting. Immediately drains new battery after first try. No error codes. Going Nuts~!
It's draining the battery or the battery is being discharged by all the cranking?
Have you checked for spark at the plugs? Is the fuel pump switching on DURING CRANK?
There is a fuel pump check terminal on the secondary diagnostic connector located beside the OBD connector.
DIAGNOSTIC CONNECTOR (viewed from terminal side)
