[attachment=17840:03_Elantra_2.JPG][attachment=17839:03_Elantra_1.JPG]
There are two hoses running directly from in and out (Block to Heater). The question is which one is the correct hose?
The Hose Part Numbers are 97312-2D100 & 97311-2D100, one of this should be the heater-inlet hose. They both run parallel in and out of block.
If you're planning on flushing the system anyway remove both hoses and have someone crank the engine over while you watch to see which one coolant pumps out of. I *think* it's the driver's side hose that feeds the heater core but it's been a while since I did a coolant change.
