I need to replace the throttle position sensor on my 2002 santa fe v6 2.7 l. The mechanical swap out looks simple enough. However, the repair manual reads that a "scan tool" needs to be utilized and readings obtained to calibrate the install.
Considering that I have two questions:
1. Has anyone replaced this module, and if so, was a "scan tool" used in the process, and what is it's purpose?
2. Is a scan tool the same as a OBDII reader, and if not, where can such a tool be purchased?
Thanks ahead for any responses to my post!
Out of curiosity, why are you replacing it. Beyond that, you need a scan tool so that you can read where the position is so that you don't fool the computer into thinking that the throttle is open a percentage when it's at zero. An OBD2 reader that can read live data can read the data you need to monitor.
The reason I ask why you are replacing it is that we had a problem recently where the Fe would only go about 20mph and it ended up being the electrical plug was loose/had dirty contacts. I used electrical contact cleaner in a spray can and some dielectric grease on the pins and took care of the problem, solving the need to buy an expensive part.
Firstly, thanks for taking the time to address my post.
My santa fe is triggering a code that shows a defective throttle position sensor. Only symptom I have is poor gas mileage. Will a defective senor cause poor millage? I may try cleaning mine as well. Also, can a sensor be replaced and re installed in the same orientation?
One more question, I take it a 16 pin data link scan tool a standard ODBII scanner. the repair manual states when installing the TPS the reading on the "scan tool" should be between 250-800 mili volts. Is the voltage reading a function of ODBII scanners?
Thanks ahead for any reply!
Where did you get the manual with the specs for live data
Sent from my XT1635-01 using Tapatalk
