Ok here is what I got going on. I replaced all coil packs. I get spark on every other plug. No spark on 3 & 6 I have power going in this coil pack 3&6 but nothing comes out of it. It will crank and run but no spark on 3& 6 ????? What should I do ??
We don't need two threads to deal with this...2002 hyundai santa fe v6 no spark only on 3&6
This is my 1st reply so bare with me. But I just recently fixed my 2002 Hyundai Santa Fe Lx 2.7L which had no spark but would crank until the Battery died. But I replaced the Crankshift Postition Senor, and that fixed my boot spark problem and it started up as I turn the key. So I would try that out if you hadn't all ready
Welcome to the forum Kc63136.
I don't think a faulty crank sensor would cause only 1 of the 3 coils to stop firing. But crank sensors are a common failure item on the 2.7 engine (see beow) so it's always worth taking a look at it anyway.
