hi i have a question i have a hyundai accent 2002 the check engine light is on so i took it and it read p1529 and one of the guys said it was the computerto the engine idk can someone help me and explain it
QUOTE (pallaso @ Sep 24 2010, 03:28 PM) index.php?act=findpost&pid=358502
1529 is request from TCM to the PCM to illuminate the MIL...
Kinda like me calling you to turn on the lights..
You will need to gain access to the TCM to obtain the codes in the trans control module..
If you find a code for output speed sensors, test it first, there is TSB, if good, program TCM with #18..... if sensor out of range, replace sensor and program TCM with #18..
There is a couple engine programs to upde too..
Hi, I got the same code read and it came along with code P0715 which means Input speed sensor (part of the tranny). I replaced the input speed sensor (cost $80) and both codes disapeared.
