Hi there, found the site through google.
The problem I have is that the car will not start, There is no spark at the plugs,It spins over quick enough, the battery shows 12.24 volts even after its been churning for a while, a jump start doesnt help either.
Ive put a jump lead from negative to block to rule out a bad earth, have tried the spare key incase it was a fob problem but nothing.
Any ideas? if it was an imobilliser, would the engine even spin over?
Off-hand, I'd suspect a failed sensor, but first I'd check the ECM for diagnostic codes & unless you've disconnected the battery, that should tell you something.
