Both power outlets on my 2001 Sonata are inoperative. I have checked the fuse box in the engine compartment. There is not a marked fuse for the power outlets. I pulled every fuse and checked the fuses visually and with a VTVM for continunity. The fuses are not blown and and peg the needle on the Simpson Ohm meter. Is there a fuse in a different location? What is my next step?
Fuse #9 in the passenger compartment fuse box according to ETM at Hyundai service site.
Refer to "Fuses" in owner manual too, should have daigram to aid you in locating fuse,, likely marked "CIG"
Thank you. I never suspected the fuse box would be on the firewall. Not the easiest location to find or see what one is doing.. All fixed now. Thanks again.
