Hello Everyone,
I am in need of the communities expertise. I have a 2001 Hyundai Sante Fe that died on me while driving down my street. The engine sounded like it was loading up for about 1-2 seconds, then it died. It turns over but does not fire.
After a little troubleshooting, I have no spark in cylinders 1 and 4. I swapped the two coils thinking that I had a bad coil, but then the suspected bad coil created spark on the 2-3 cylinder side. So both coils work.
I towed the car to the shop and the mechanic after about 2 hours of billed labor, he is leaning toward a bad ecu. He said there also is no fuel metering from two of the fuel injectors. He checked the resistance on the injectors and said they are fine. He is thinking it is a control/command issue. The car has many other unrelated problems and I am not sure I want to spend too much more money on it.
I am skeptical about a bad ecu. Can anyone think of a sensor, or sensors that may be causing my two cylinder no spark and alleged fuel problem?
The car is at the shop as I am typing so the faster someone can chime in the less my labor cost might be
Thanks in advance,
Victor
Thanks in advance,
Victor
