1 - 18 of 18 Posts
Cranks fine.
No 12v to the fuel pump relay coil, have 12v to the fuel pump relay terminals. Bypassing the relay gets the fuel pump running but the car still will not run.
All fuses are good. All relays are good.
Any other ideas will be most welcome.
jwcharboneau
2007 Honda CRV
Don't know the reason why there is no control side voltage to turn relay on
Don't know if the relay is any good
When it won't start, check for fuel pump to prime fuel rail
Check also to see if there is spark at the plugs
If you have one but not the other then must follow that line to find issue
If they are both out then may be crank sensor
Good luck
Test the 12V supplies at the relay socket on the fusebox and see if one is missing (there should be two when the ignition is on).
Next do a relay bypass test then check that you have 12V on the ECU fuses with the 30 & 87 terminals of the relay socket bridged.
If the relay power supplies are OK, and you have 12V on the ECU fuses when the relay is bypassed, you know the problem has to be the relay coil ground.
The relay coil ground comes from the engine PCM. It's a switched output that the PCM sends to the relay when the PCM receives an input from the ignition switch. In other words, when you turn on the ignition the PCM is supposed to turn on the engine control relay, by sending a ground to the relay coil.
Off the top of my head, there are three possible reasons for there being no ground at the relay coil....
1. the relay control wire is open circuit/broken between the PCM and the relay.
2. the ignition input wire is open between the fusebox and the PCM (you have checked ALL the fuses....right?)
3. the relay driver inside the PCM is faulty (highly unlikely, but can't be totally ruled out at this point)
Discussion Starter · #8 ·
Haven't checked the 12v as you suggested, went directly to bypassing the ECU relay and the fuel pump relay. The car still won't run.
To my mind, things are pointing to the ECM (this model has an ECM vs. PCM) being the problem.
However, I'll go through all the checks that you suggest tomorrow, just to confirm.
Thanks for your help and suggestions. If you think of anything else, please don't hesitate to say.
Discussion Starter · #12 ·
Not back to post 1. ECU fixed the no start problem. The fuel pump issue started 1.5 days after the ECU was replaced.
Near as I can tell, it's an open wire from the fuel pump relay to the fuel pump itself, but I don't like that explanation. Without a clear wiring diagram though, it's the one I'm stuck with unless someone here has another option.
We can't really give you another opinion at this point because we don't know what steps you've taken to reach the conclusion that the pump circuit is open?
Is the pump relay switching on DURING CRANK?
Is there power to the pump check connector DURING CRANK?
FUEL PUMP CHECK CONNECTOR LOCATION
1 - 18 of 18 Posts
