My 2001 Santa Fe headlights will not turn on (low or high beam). Also the fog lights would not turn on. I checked the fuses, but I am not able to locate the relay or a print on how the system is wired. When i pull the lever back towards the steering wheel the head lights do turn on. I am wonder if anyone has seen this and couple possible give me some advice.
Thanks
Thanks
Head Lamps/Fog Lamps diagrams attached.
Headlamp Failure
Yes Scottie,
You did cover the matter thoroughly. In fact, about three days after
the final post, both my headlamps died on low beam. High beams were
fine and the stalk flasher worked too. I just knew that the connector test
and jumper you suggested was the answer. No, the lamps were still dead.
I broke my golden rule of "KISS", keep it simple stupid. The last thing I
did was to check the bulbs, they were both bad. I know I should have
done the bulb check first, but failed to keep it simple. Another lesson
learned.... :)
Paul
I would like to thank everyone for the help. Scottie, your stuff gave me lots of good information. I did the bypass and the lights worked but when I was ohming out the switch I couldn't find anything wrong. I ended up finding that terminal 15 on the wiring harness was not pushed in all the way. As soon as I pushed it in everything started working again.
Thanks again for the help!!
Chad
Hi Chad.
Thanks for taking the time to post back and confirm the fix. Glad I was able to help and great to hear it was a simple, free repair.
