Where is transmission temperature sensor located?? I have codes u0d00 p0711 p0430 p2300 any know what I need to fix ?
Sensor is on valve body. You need to pull the transmission pan to get to it. Or check and change the fluid first to see if it helps
P2300 is ignition coil related and also probably causing your P0430 code. Check ground and all wiring
Ok thank you!!Maybe I’ll change the transmission fluid!!! N I had a new ignition coil put on and all new o2 sensors!!!
You need to first address the ignition coil code first. Any ignition issues will cause emission codes. However, once corrected and reset those emission codes should clear if the pre cats are in good shape. What O2s did you use? I chased my tail with emission codes for three months with Bosch generics O2s. My 2.7 only liked the NTK O2 sensors.
Also, did you change the plugs and wires?
Used Denso O2 sensors and yes replaced ignition coil plugs and wires!!! Will be changing the ignition coil it could be a bad one I’ll try that first
