i have a 2001 hyundai santa fe 2.4l whith this same problem the thing is i already have done all your suggestions and is not working still, what else could it be?
i have checked:
gasoline pump
ecu censor (replaced)
cranckshaft censor and blade (replaced)
camshaft censor (replaced)
cam censor plug broke and wire with the diagram you display
only crancks but doesnt start.
Hi,
Do not understand exactly your problem, not starting??
What or where is an ecu sensor? What did you replace?
Normally for startup the camshaft sensor is most important for timing.
Cranckshaft sensor is more for timing the running engine.
But also ignition. Do you have sparks?
Do you have a check engine light on? Are the error codes?
Good luck,
Paul
