Hello everyone - I am new to Hyundai ownership, and brand new to this site. I have a problem with a 2000 Hyundai XG30 that I bought a couple of months ago, and am hoping someone might be able to give me some advice, judging by your previous postings/replies. I bought the car cheap, with three fully disclosed faults.
1. The car seems to knock too loudly on the front suspension, when the car goes over road bumps/uneven surfaces, despite the factory 17" alloys and 45 profile tyres. This is annoying when the ride is otherwise so smooth.
2. Both front seats no longer heat up, which I think is probably not time or cost effective to remedy.
and,
3. The biggest problem is with the engine (as you probably guessed). The car is now almost undriveable, and has become in some respects dangerous. When I bought the car, it had a tickover/idle problem. If it hadn't been driven for 24 hours, you could start it and it would generally be fine, despite the low and slightly rough idle (500 rpm). BUT if you stopped the car at a petrol station, or at the shops, and then tried to start it again, the fun and games would start. The car idle starts to fluctuate between 300 and 1300 rpm, and then stalls completely. You cannot start the car and leave it in neutral or park, as the revs will just drop and it will stall. The only chance of keeping the car running is to immediately put it into drive or reverse, when the engine seems to resist stalling slightly better when it’s under load, although the idle is still low at about 500 rpm. Once on the move the car is better, although the engine still cuts power and jerks every few minutes or so. When braking to a stop the car now just stalls almost every time, and I can't get it to start again in neutral or park unless I give the accelerator a considerable amount of revs. Then you have to immediately engage drive and abruptly pull away. The more times I stop the car, or it stalls by itsellf, the harder it is to restart, and poorer it runs if I do manage to keep it running.
Looking online, suggestions seem to suggest problems with MAF sensor, AIT sensor, vacuum leaks, and faulty EGR valves. I know the previous owner changed the MAF sensor prior to me buying the car, but he admitted it didn't stop the revs/stalling issue, it just returned the MPG's back to the correct level.
I have spoken to various Hyundai garages, and they have never heard of an 'AIT' sensor.
I am vaguely aware of how to test for a vacuum leak (from viewing utube videos) but I don't think I will be able to keep the car ticking over at idle long enough for me to start spraying susbstances around the intake manifold.
From looking on utube, changing a faulty EGR valve looks like just replacing a hose, which obviously I could do.
Do anyone have any experience of the above, and is there any advice you could give in relation to it. I bought the car because I am hard up, and it was cheap. I can't afford to take it to Hyundai for them to mis-diagnose the problem and charge me a small fortune in the process.
Desperately hoping someone can help, and thanking you in anticipation
Kindest regards
Mark (Cruisers).
and,
Kindest regards
Mark (Cruisers).
