I have a 2000 hyundai elantra and I was doing some repair work and the ignition coil wiring connector was busted on the coil side and on the car side. I have no idea which wires go where. I tried calling the dealership but they gave me the run around. The repair manual I have doesn't give me the wire colors on the coil side. the terminal side is brown, green, and white. The brown going hot with the ignition on. The wires on the coil side are red, black with a white stripe, and white.
Any help would be greatly appreciated.
Hello I’m having the same problem with my 2000 tiburon but mine broke on the car side and was needing to know if u know witch wire went where...if the brown wire is in the middle or is the green wire in the middle
