Hi All
I see its quite a common fault now with Grandeur/XG300/XG350 that have the dashboard shrink and curl up around the air demister vents.
Has anyone found a way to fix this? Cant find anyone to do any repair. hate it.
Also Minor Question, the Climate Control panel used to make a beep sound whenever you made any adjustment. this has now stopped. any suggestions?
Nothing in the owners manual.
Many Thanks
It’s always garages and whenever in the sun a windscreen cover.
Surely there is a way with heat gum and mould it back down?
If you can do it there are many people that would pay you to fix their dash problems. These are blow molded and you are not going to get them back to normal without remolding. You will likely make it worse by trying to fix it.
Please post pictures of your progress.
