2017 Sonata Sport 2.0T
Does the 2.0 T engine use a MAP or a MAF sensor in the intake? I think Ive seen that it is a MAP.
If it is a MAP is it safe to use a GDI cleaner like CRC directly into the throttle body and not have to worry about damage like if it had a MAF? Or is it a better idea to fins a vacuum port after the throttle body and add it there?
Thanks for any replies.
MAP Engine, the good side of doing it through the throttle body is that you will clean the plate at the same time
Thanks, I was hoping that was the case. Much easier to just remove the air filter or air box and spray from there
