hello just bought my 1999 Hyundai Tiburon about 2 weeks ago and i blew one of my serpentine belts the one that goes from the harmonic balancer to the air conditioning pulley and replaced it and now it wont start. i have checked all fuses and the gas pum there all fine i have also checked for spark all is working any guesses at this problem let me know thanks.... alex
Maybe when your serpentine belt went poo-poo it ripped out the wires to the cam sensor located on the back of the motor around cylinder one on the head? Cam sensor controls fuel injection timing, so you wouldn't get fuel even though you have good fuel pressure.
hello thanks for the info i will check that is very possible because when it cranks over there is a weired noise coming from the back of the motor now its hard to explain the noise but it sounds like it is turning empty if you get what i mean so i might not be getting gas but i have also pullled the spark plug out and can smell gas on the end of it ? thanks...
