Is there a dedicated fuse for this? I suspect its a wire problem. I opened the center dash to clean under the shifter. Is there a connector there that I might have knocked loose?
Yeah, it's normally on the dashboard fusebox and is normally mounted in a yellow plastic carrier. So it's normally easy to identify.
PS....I don't normally say normally that often :laugh:
I'll be a sob. Murphys law. I had voltmeter on a.c. when checking the domelight voltage. Turns out that new LED bulb lasted only a few months.
FYI slot # 6 for "room Light" fuse.
