I lost the manual and I need a diagram for the fuse box so I can change the brake light fuse.
Can anyone help me?
Thank you!
:00000732:
I light of not having a manual and needing to change a fuse, I would resort to checking each fuse individually. Brakes are usually on a constant power fuse so it should be easy find. Just check for power with a test meter on both sides of the fuse.
Dear All,
I need the wiring diagram for camshaft position sensor, what is the value of positive voltage(+). in my car I have problem in camshaft position sensor. I had tested the supplied voltage, it was 4.5 volt
please I need help from your side.
Thanks
