My daughter has 1993 Excel that she uses to commute to college. The high beams work but not the low beams. I replaced the light and that is not the roblem. What else? Any ideas? Is there a headlight relay?
sonds like that there is a problem in the power feed at the under hood relay box (connector E01-4). loosen the relay box, and check all the wire terminals for corrosion.
I had same problem with my 93 excel a few years ago. It was the low beam relay unit. The spring had lost its tension. I recommend you check the relay which is located in a fuse box in the engine bay.
Hyundai Forum is a community for all Hyundai Owners to talk and learn all about their favorite subject: Hyundai cars from the Sonata to the Elantra and even the new Kona!
