1 - 11 of 11 Posts
Guys,
Im looking to replace my 16'' rims on my 08' GLS and install 18'' OEM ones.
I couldnt find any use ones.
Did any one done that? If yes how much did you pay for the rims and the tires?
And how muc hi could get for the set of 16''.
Also i couldnt find anywhere on the forum about the replacing the fog lights...
The GLS has just the caps and i dont like it...any suggestions...
Thanks
To install the fog lights you have to start from scratch and buy the lights and any mounting brackets. buy a fog light switch and then fabricate the wireing harness and relay to work with the headlights and still look stock. I have done this on 3 SanteFe's for the dealer I work for after they promised Fog lights to a someone to make the sale. Cost them about $500.00 a car.
What parts did you use it? lights, brackets? SO there is no oem kit , right?
thx
QUOTE (tech1 @ Apr 18 2010, 06:03 PM) index.php?act=findpost&pid=314405
QUOTE (nxvds @ Apr 18 2010, 01:23 PM) index.php?act=findpost&pid=314324
Guys,
Thanks
you casn go too www.partsgeek.com, they have 18 '' rims
QUOTE (nxvds @ Apr 19 2010, 02:10 PM) index.php?act=findpost&pid=314644
Considered those
http://www.tirerack.com/tires/tires.jsp?ti...&tab=Survey
before deciding on these:
The size is a bit off since they don't make the OEM size in the HTS, but the diameter remains within a hair's breadth of the OEM, so no speedo issues. My Bridgestones are starting to look a bit thin, so it's time to order up.
1 - 11 of 11 Posts
