Anyone in the 150K yet with there Santa Fe? If so what issues have you encountered?
The odometer on mine just turned 110 today. Need 200K outta this girl before I can even think about a newer car.
Mine has 93k miles. I've recently:
* Changed ATF Oil
* Changed Spark Plugs
* Engine air filter, cabin air filter
I have 105,000 on my 07. Just normal maintenance other than a couple sensors when under warranty. Also ball joints. I am hoping for close to 200K.
I will probably do spark plugs this year and flush brake fluid which has never been done. I drop out the trans fluid every year and replace about 4.5 qts at that time.
What year is yours?
Items that have failed on my 08.
-control arm
-radio
-caliper
-valve cover gasket
-3 sensors
Overall good car but not Honda or Toyota quality in my opinion but you can't buy a Toyota or Honda for the price of a Hyundai so it's a wash.
Not bad...heck I have a Mercedes that had the radio go out within 50K at my expense. Also had a DEF pump go out under warranty. That would have cost me a couple thousand bucks. Also some kind of sensor. And oh, a tail light wiring issue. And that is for a nearly $50,000.00 vehicle.
Nothing is perfect.
