Back when the HD cars were originally on the lots and all the car magazines were road testing them, it was frequently mentioned that the SE models had stiffer springs than the GLS models. Look up most any road test from back in the day and they mention this.
Looking at parts websites ( OEM ), it seems there is a different coil spring for non-A/C cars and cars with A/C, but I can't find any difference in the coil springs or struts from GLS to SE.
If anyone can clarify this, appreciated.
Discussion Starter #2
figured it out, i think
After extensive research, I think I have answered my own question. Not all parts websites give good differentiation between sport suspension and non, etc.
Here is what I've come up with for springs for the SE cars, i.e. the stiffer factory setup as fitted in MY '10, should fit all 07-10 cars:
Front springs 54630-2H410
Rear springs 55350-2H221
Front struts L 54651-2H200
Front struts R 54661-2H200
So if you wanted to convert your GLS to a stiffer setup than stock without loss of ride height and using stock parts, you'd need the above from what I can gather. Thought I'd post it all in case anyone else wants to do this down the road.
