I’m having a issue with my 2008 Elantra that hot or cold is only coming out of the floor vents and maybe a little air flow on the front facing vents .I heat ac works it’s just that the vents aren’t changing.I pulled the glove box out and took the actuator off and moved it by hand and I still cannot get air to come out of the top vents does anyone have any tips to fix this ? Thanks
I don't think you did the correct door.
^^^what he said^^^
The mode actuator is on the driver's side of the heater box. I doubt you'd be able to access it by removing the glovebox.
