1 - 8 of 8 Posts
This will be the first antifreeze change on the '08 and, most likely on the '11 also. Not positive about the '11 'cause we bought it used.
Any gotcha's I need to know about?
Is there a block drain, or will the entire system empty satisfactorily through the rad drain?
Thanks all!
slmjim
2009 accent. Found my drain plug in a very convient place. A blue phillips plastic plug with a "o" ring on it. Removed the plug drained the coolant and replaced ith just a little over a gallon of premix coolant. Easy Peasy. will do it again a few more times just to make sure its all nice and new.
Helps to give it a flush with the garden hose just to remove any deposit buildup where corrosion will still occur under the sludge even with new coolant. I like to take the bottom hose off and also a heater hose just to make sure. If it's currently clean it's probably no big deal.
Pull the hose off that comes from the water pump across the front of the motor. A lot more coolant will drain than just the radiator drain.
I'm doing mine one gallon at a time. Find the little blue/green phillips plastic screw on the very bottom of the radiator. remove it with a catch pan under it...then...remove the top fill cap to release the air flow. Measure how much came out. In my 2009 accent hatchback it was one gallon. I will probably do this about 2 more times to change out the majority of the coolant. You don't even have to jack it up. Slowlane
Discussion Starter #7
Thanks for the replies everyone.
slmjim
I use Castrol coolant test strips to test every car and you know when a coolant change is required so you don't waste time and money.
1 - 8 of 8 Posts
