1 - 19 of 19 Posts
Hello all,
My Elantra was at around 120k miles and due for its timing belt replacement (I elected to replace the belts and water pump etc/using a kit) When I picked it up the car from the mechanic it was making a squeaking sound that was very noticeable especially when accelerating from 0-20, but is audible at all speeds. I immediately notified the mechanic and he said there was likely some air in one of the lines and that it should clear in the next few weeks but if not to bring it back.
Fast forward one week and the squeak hasn't gone away, but today was a hot day and I decided to use the AC and was surprised that I only got hot air out of the car even after the AC ran for 10-15 minutes. I opened the hood and didn't see any movement in the serpentine belt when the AC was on (however I'm not knowledgeable enough to know if this runs intermittently)
Anyway, to me this seems like a straightforward error by the mechanic, but I guess I want to make sure if my logic is reasonable or if the mechanic might come back saying something else is wrong. Up until the timing belt replacement I have had no problems with the AC but I have never had it recharged.
2007 Honda CRV
All the belts should be moving.
An electrical clutch is what engages and dis-engages the AC compressor.
The belt may not have been tightened or something came loose??
Hello all,
Air in what? Ask him
The belt wasn't moving. The engines running and the belt doesn't turn?
Answer my questions and we will go from there.
Hello Grcauto...
He said that he thought that air must have got in the water pump line during the replacement and that it would naturally work it's way out but if it didn't they could blow it out later on. However he told me this listening to the sound in the car, we didn't open up the hood at the time. At the moment this seemed like a legitimate explanation. (this mechanic got great reviews from our neighbors)
Second, after watching a couple youtube videos to get familiar with the engine components, it looks like when I start up the car I can see two belts, one which is the timing and the other very close by but slightly further back which I believe is the serpentine. When the car is in idling the serpentine belt is definitely not turning when I toggle the AC on or off. I watched for about 10 minutes.
Hello Grcauto...
You need a different mechanic....that is ludicrous. You can't blow air out of a cooling system. Not possible and never been done. Air in a cooling system will not make a squealing noise. I've been in the business for 45 years and it's never happened.
Your neighbors need a new mechanic as well.
The timing belt he replaced is behind the covers and can't be seen. The belt in the front is the serpentine belt and the one behind it is for your AC. He never tightened it back up correctly which is why you are hearing the squeal. This is also why your AC is not working.
Your mechanic should be pushing a broom in a garage and not working on cars.
You should update your profile with the vehicle you drive and where you live.
What state are you in? Here in Michigan if you run a legal business you have to be certified to work on them.
You should quote to respond. That way I get an email that you responded and I can reply. I just happened to come back here.
I would not use that so called mechanic again.
Thanks for the feedback...I updated the information for my profile (Denver Colorado/07Elantra). So if I understand you correctly likely the belt I see running is the serpentine belt and the one further behind is the AC belt which looks like it is stuck. Listening again the sound is coming from that specific area. Thanks for the comments.
I tend to be a bit harsh on shops that display ignorance. My comments about the air in the system and it not creating a squeal are justified.
That being said, maybe he was having a bad day and didn't really hear the squeal. I don't have the best of hearing myself.
Let's move on. If the belt is squealing it's because it's slipping around a tight rotating devise like an idler or compressor and most likely WILL NOT be just sitting there. Also, if the squeal is the belt it'll start smoking and break before long. Just minutes. Are you sure the belt is not moving?
Discussion Starter #8
Thanks for the comments....It made me better armed when I went back into the shop. I think I have a final resolution with this. I ended up taking the car back and they spent at least 4 hours looking at it. The head mechanic told me two things. The timing belt was slightly too tight making the sound and they reset the tension on the belt and that eliminated the noise. They also said that the A/C belt had been put on too loose and they had to tighten it. I picked up the car this morning and the sound was gone plus the AC is working just like normal.
The head mechanic apologized for the inconvenience and said that they had fired the mechanic who had worked on my car due to poor workmanship issues. I didn't want anyone to lose their job over this, but obviously, those were two big mistakes that he made. I'm assuming the first mechanic didn't do proper quality control before giving me the car back the first time.
It sounds like my criticism of the mechanic was well founded. Glad they got it fixed correctly. Did they charge you anything more?
I do not understand one thing....the timing belt does not get adjusted. The tensioner is spring loaded and has no adjustment.
... The timing belt was slightly too tight making the sound and they reset the tension on the belt and that eliminated the noise. They also said that the A/C belt had been put on too loose and they had to tighten it...
I would certainly have insisted that they replace both belts with new ones. Having the timing belt too tight didn't do any favors to it. Was it tight enough to stretch it? Did this shorten its life?
Having the AC belt too loose is bound to have caused the drive pulley to have worn away part of the belt. I would be pretty sure that its life was reduced.
Are these adjustable?
If it's adjustable it may have.
Absolutely correct.
Discussion Starter #12
The comment I got emailed back from the mechanic "We ended up pulling the timing back down and found the timing belt was making noise (slightly too tight) These have a tendency to move after tightened (this is not a hydraulic tensioner it is a manual tensioner)"
...Note sure if that answers your comment.
I was not charged at all for rework they did...One of the reasons I went with this shop as well is they gave me a written warranty for the work 2 years/parts and labor.
Good warranty...The tensioner is not manual. It's spring loaded and not adjustable.Something don't add up. Anyone else want to chime in. @AUTOSPARK @joegr @avisitor
Should have updated. That tensioner is a manual and needs to be adjusted and tightened. Not spring loaded.
1st style tensioner, rotate - hold - tighten bolt
Later to include HD Elantra 2.0,, rotate tab to preload pukkey to belt and arrow indicator hiding in back, line it with slot, and tighten belt..
I generally have pics somewhere of something that might come up
  • Like
Reactions: grcauto
When i replaced my timing belt, it moved every time after tightening down. It's comforting to hear your mechanic confirm that because I thought I was going nuts. I tried numerous times and every time the arrow moved afterwards.
Did your mechanic say what their fix was for how to prevent movement after tightening?
Good day, im driving a 2007 elantra avante ,i went to Hyundai and they told me the car uses timing chain, which elantra are you using
2007 Honda CRV
Not all models have the exact same parts in them
Depending upon the production year and changes made during the production
Also, some recalls will change things too.
1 - 19 of 19 Posts
