I have an '07 Sonata that the parking lights and dash lights come on randomly or stay on when the car is turned off and lights turned off. I have read several posts online about the relay in the passenger compartment fuse box sticks and causes the lights to stay on, I bought a new fuse box and replaced it with the same result, anybody have the same concern that can help me out,
Thanks !
Thanks !
Plenty of posts on this...
00000732
* Do a search for your problem. A lot of stuff has been asked and answered.
Thanks,
Welcome aboard.
00000732
Thanks,
Welcome aboard.
Thank you, how do I search previous posts ?
Most of the previous posts are at the link below. Somewhere in that thread (post #47, I think) I suggest a cheap fix which removes the faulty relay from the circuit rather than replace the whole fusebox. That has cured the problem for a few folk on the forum who don't mind doing a bit of DIY.
2006-2010 NF Sonata - Parking lights stay on
