Ok,
Hi I'm new here and I have looked and looked but can't seem to find what I need.
2006 Elantra
I can hear the washer motor working but no fluid is coming out. The holding tank is full.
How in the world can I get to the motor to see what's going on? It seems like the car was built around it?
I'm not loosing fluid, because none is hitting the pavement.
Thanks,
Buzzy
Did you wax the hood and smear wax in the sprayer nozzle? I do that all the time. I just get a bristle from a wire brush and clean it out.
if the above answer does not work you will need to renew the pump, it quite common. remove the right hand front wheel and the inner plastic fender shield to gain access to the pump
there is a small electric pump that's fitted in the base of the washer fluid bottle,its common for this to fail
