Where is the 05 tiburon v6 crankshaft position sensor and camshaft position sensor and how do i replace them?
It's on the front of the engine, just in a little from the gearbox flange...see below.
The sensor is held on by a single M6 (10mm) bolt. Undo the bolt and wiggle the sensor out of the block....easier said than done a lot of the time.
There's a rubber 'O' ring that seals the sensor hole. Make sure that comes out along with the old sensor. If you leave the old 'O' ring in the hole your new sensor wont seat properly and your engine might not start.
