1 - 1 of 1 Posts
After replacing the alternator and the valve cover gasket on the front side of the motor a misfire developed the car now has new spark plugs spark plug wires mass air flow sensor new harness to the coil packs new coil packs new fuel pump the timing belt and crank position sensor are fairly new less than 6 months old and no check engine light any suggestions would be very much appreciated
1 - 1 of 1 Posts
