I recently purchased a 2004 Santa fe with 180,00 miles on it. Drove the vehicle for over a month before I had an issue with it not starting. When I turned the ignition to start I had no crank but all the appropriate dash lights came on and I can hear the fuel pump working. Since this first incident I have had a new battery installed, a new neutral safety switch installed and a new starter but the problem still happens. When it does this I turn the key off and then try again, it starts. Any ideas??
First try to clean the battery posts and cable terminals
Then follow the negative battery cable to the chassis
Clean the contacts and terminals of the ground
Then if that fails to fix it then replace the ignition switch
