1 - 1 of 1 Posts
Hello everyone, I have a 2004 Hyundai Elantra gls with abs brake system, the car is in really good condition for its age, no rust under neath. The problem is the right front passenger wheel was locked up when I went to leave. I replaced the caliper and the flexible brake hose. I inspected all brake lines going to abs and then to master cylinder, all good. All other wheels turn freely. Here's the kicker, I take off the master cylinder cap and can press the caliper on the drivers side easily and fluid returns to reservoir, when I try to compress the caliper on the passenger side, it does not move, no fluid is going back to the master cylinder. I can only release the cylinder with the bleeder. I apply the brake again and drivers side spins, the passenger side is locked up. What would cause the fluid not to go back to master cylinder? Thanks
1 - 1 of 1 Posts
