Hi all,
Looking to replace my 2 rear lines (drum brakes) with after market lines. I've traced the lines to measure for the lengths I need, but forgot to check if there is any sort of junction block going mid-way to the rear or are the lines basically straight from the master cylinder to the hose connectors?
Also, would anyone know the size/specs of these lines before I remove and matchup at the auto parts store? 3/16, 6mm, etc.... As I'd like to order up front before removing.
Thanks very much!
Thanks very much!
