1 - 1 of 1 Posts
Not sure whats going here, brakes are less than 2 weeks old all around, starting getting a mild metal on metal sound (almost like warning bar on the pad) about a week ago, on the front drivers side. I took a good on the weekend and discovered the dust cover was making contact figured problem solved and positioned it back from the inside of the rotor. Took the car for spin and the noise was still there. Again pulled it apart pads and ended up removing the dust guard all together as it appeared to move back toward the rotor. this time the noise was gone.....until later that night when I was out. I'm completely stumped as the noise wasn't there before the brake job, I feel nothing while braking and there's no marking on the pads or rotor to indicate contact. Has anyone encountered anything like it.
One other quick question, is the early wear warning on the inside pad supposed to be on the top or bottom when installed in proper position?
1 - 1 of 1 Posts
