Should attempt to start today 07-28-10....it wasn't as bad as expected...had to disassemble the entire dash down to a bare firewall to remove the wiring harness....Things I've changed so far......inside compartment...ECM, SRS, under dash fuse box, wiring harness.....engine compartment...V6 engine cradel with wiring harness attached, cruise control servo, both throttle cables (tip) when you replace the foot pedal cable which has a round locking ball on it...as your trying to feed it back through the firewall the top of the foot pedal will be pressing against the hole in the firewall making it appear the hole is to small for the ball to pass through just press down on the pedal and place something behind it to hold the pedal off the firewall.......both fuel hoses on the firewall and both heater core hoses, fuse box.....
Discussion Starter · #2 ·
The project was completed on 07-30-10....with the final test of placing the car in drive and preforming a series of test on all operations.......They all passed with flying colors......it drives and has the preformance you expect from V6....now I'll road test it and log the next 1,000mi......
