recently bought a santa fe gls 2.7 auto. loving it so far, but when it comes to shifting gears ive noticed it sometimes takes up to 4.5k rpm especially 2-3rd. now just wondering if this is normal or should i take it back to the dealer?
thanks
Have it scanned for DTC, and while hooked to GDS, hit the ECU UPGRADE button and see if any updates available.. both engine and A/T
In the mean time, something you can try on your own... get the thing good and hot.
2004 --> disconnect Neg battery cable, and touch cable to positive post to kill the memory.. Re-connect cable, and since car is HOT, you can start "learn" process right now.
Start engine, foot on brake (do this in residential with long streets), shift from P-R, wait 5 sec, R-N, N-D, wait 5 sec, repeat about 12-15 times..
Now in D, carefully drive at no more than 25% (kinda hard with out scan tool for throttle data) throttle, and allow the trans to shift up through all 4, roll down to stop, do this about 3-4 times... you may find you need to accel a wee bit to get speed to get speed to allow upshift, just dont hammer the pedal.
After that, I usually start from a stop in the manual shift mode, start 1, take it up to about 2500, tap shifter for 2, and do same for 3 & 4... do this a couple times.
Now take car for a drive in "D" and see how it acts.
