2006 Azera Limited driver side power seat motor - Hyundai Forums : Hyundai Forum
 1Likes
  • 1 Post By AJC9
post #1 of 4 (permalink) Old 01-27-2018, 01:20 PM Thread Starter
2006 Azera Limited 1979 Chevy Malibu Classic 1997 F250
skippyjohnjones is an unknown quantity at this point
I just bought a 2006 Azera from a little old lady. The car was garage kept and only has 35,000 miles. I never checked the power seat before I bought it. My wife went to move the seat forward and there is nothing. Right now the seat is all the way back. The seat moves up/down and the tilt back/front work. I took the side panel off and checked for continuity. The switch checked out good. I then checked for voltage, and that was good as well. I tried looking for the seat limiter but could not reach it. At this point, I was pretty sure the motor on the front of the seat frame was the slide motor. I was able to unplug it. I am getting voltage when the switch is pressed in the forward position. There is nothing when pressing the back position. It seems like all of the switches are working correctly and it would be a motor problem.
If it is the motor, how do you remove it? I struggled to get the 2 Phillips screws out only to find it does not lift out. I can't get the back 2 bolts uncovered to pull the seat out of the car because the slide is over the plastic bolt covers. Is there some way of manually sliding the seat front?
thanks for any help
skippyjohnjones is offline
post #2 of 4 (permalink) Old 01-28-2018, 12:19 PM
2005 Santa Fe 2.7 2006 Azera 3.8 2013 Sonata 2.4
Quoted: 4 Post(s)
AJC9 is an unknown quantity at this point
Here is a schematic that was helpful when i had the same problem, but with the tilt. I thought my switch checked out good, but that wasn't the case. See if you can apply power to the slide motor via pins 8/9, and then reverse polarity depending on direction. If it moves both ways you know you need a switch. This test will bypass all the other circuity and fuses for the seat so use caution so you don't burn anything up.
Hopefully that helps or the schematic points you in the right direction
AUTOSPARK likes this.
AJC9 is offline
post #3 of 4 (permalink) Old 01-28-2018, 02:18 PM Thread Starter
Thanks for the information. I didn't think to actually apply power to the motor. I'll give that a try. I am having a hard time finding manuals for the car. I was hesitant to sign up for the online service manuals since I was not familiar with them and don't know the quality of information. I really don't like the idea of paying a yearly fee each year for information that doesn't change that much. Is there one that is better than the others when it comes to these cars?
Thanks.
post #4 of 4 (permalink) Old 01-29-2018, 03:13 AM
Drive 2009 Azera TG, 2007 Accent MC, 2009 Sonata NF, 2010 Genesis BH,
Quoted: 185 Post(s)
wongpfh is an unknown quantity at this point
Thanks.
Power Seat info attached.
wongpfh is offline
