wont start - Hyundai Forums : Hyundai Forum
post #1 of 5 (permalink) Old 05-26-2019, 03:03 AM Thread Starter
dhongs is an unknown quantity at this point
wont start
Terracan 2.9crdi model 2004.
Yesterday I had to change the valve cover so I removed the pipes from the common rail that goes to the injectors and unplugged the electricity from them and then I removed the cover. Put the new cover on and put everything back in place, pumped fuel with the hand pump and started the car, it good ran for about 10 seconds and shaking then it stopped. Now I can't get it to start. I connected it to computer but no errors. Anyone have an idea what could be wrong.
dhongs is offline
post #2 of 5 (permalink) Old 05-26-2019, 03:05 AM Thread Starter
i change also the pressure sensor but it same problem wont start
dhongs is offline
post #3 of 5 (permalink) Old 05-26-2019, 11:02 AM
AUTOSPARK's Avatar
Quoted: 2356 Post(s)
I suggest you try spraying some "easy start" into the air intake during crank to see if that will make the engine run.
BTW, did you mark the injectors before removing them to ensure they were refitted back into the same cylinder that they came out of?
Injectors on a CRDi engine are often coded to the engine computer. If you fit the injectors back into different cylinders you would need to change the coding in the computer. Incorrect coding doesn't normally cause the engine not to start. At least it doesn't on a Bosch engine management system. I'm not that familiar with the Delphi system used on your engine.
AUTOSPARK is offline
post #4 of 5 (permalink) Old 05-27-2019, 02:58 AM Thread Starter
yes i spray in intake start they run in 2second.. and about injector... the way that a remove. the way that i return... at same position injector.. i check the wire injector they have no false..
dhongs is offline
post #5 of 5 (permalink) Old 05-27-2019, 03:24 AM
AUTOSPARK's Avatar
Are you able to use your computer to monitor the fuel rail pressure DURING CRANK? How much pressure is building in the rail?
