Drop a wheel size or go up a tire size for better ride? - Hyundai Forums : Hyundai Forum
 1Likes
post #1 of 12 (permalink) Old 01-28-2019, 09:56 AM Thread Starter
2015 Hyundai Sonata Sport 2.0T 235/45-18 tires on stock wheels
Quoted: 2 Post(s)
gupster88 is an unknown quantity at this point
I'll make it short and sweet. Want everyone's personal opinion. Currently have 235/45-18 tires on my 2015 Sonata Sport 2.0T. WV roads are horrible as some may know. Pot holes, cracks, patches all add up to a crappy ride. Ready for new tires. Either going to upgrade to 245/45 tires or drop down to a 17" wheel and go with stock tire size. By staying with an 18" wheel and going up in tire size I gain about 0.3" of sidewall height but save money with not having to buy new wheels.
By dropping down a wheel size, I get access to cheaper tires in the future and a greater sidewall height. From anyone's experience or expertise, is it worth going the extra money to drop down to 17" wheels or is the gain not worth the cost? I am just tired of the low profile sidewalls which result in knots and rough riding.
gupster88 is offline
post #2 of 12 (permalink) Old 01-28-2019, 11:05 AM
grcauto's Avatar
Quoted: 1014 Post(s)
The vehicle is programmed for the wheel size. Speedo will not be accurate as well as shift points if automatic transmission.
Best practices for requesting help:If you haven't done so fill in your vehicle info and profile page. At upper right corner under the search box click on user cp (it's your control panel)
This info will show up to the left under your user name and is very helpful.
  • Be sure you are in the correct forum for your vehicle.
  • Do a search for your problem. A lot of stuff has been asked and answered.
  • Do not double post for the same problem.
  • Give the model year....Engine size...transmission type (auto or standard)
  • Take a single issue at a time. Posting multiple issues at once will get convoluted very quickly
  • VIN number can be very helpful
  • Vehicle history can be good. How many miles. If not bought new, how many have you put on it.
  • Describe the problem best you can. If a noise can you get a sound or video file
  • Tell us what has been done, if anything, thus far. If tests have been performed give actual results not OK or passed. If scanned for codes the actual code(s) not O2 sensor or MAF, Etc.
  • If the vehicle has been to a repair facility it would be nice if you could post a picture of that invoice/bill
  • If your vehicle is under warranty you should have the dealer check it out. If it's a problem they see many times they will generate a safety recall of TSB. This is how they know of the problem.
This information can save a lot of time and get you the answers you need much faster.
Thanks,
Welcome aboard.
grcauto is offline
post #3 of 12 (permalink) Old 01-28-2019, 12:37 PM Thread Starter
Quoted: 2 Post(s)
Thanks,
Welcome aboard.
Thank you for the welcoming and the information. Not my first forum I've been on by far. I did update my profile some but didn't think I needed to update much since the majority of my question is generic and not car or model specific. I do know I cannot be exact, but if I went to 17" wheels I would use stock 17" tire size which should be nearly exact on the speedometer. My main question is if dropping a wheel size is more beneficial for protection against rough roads or if going up a tire size on same 18" wheels provides the same level of protection.
post #4 of 12 (permalink) Old 01-28-2019, 12:37 PM
Fediej's Avatar
Drives 2008 Veracruz Limited AWD with RSE package. Gold (Metallic Beige) exterior, Black/Brown leath
Quoted: 52 Post(s)
Fediej is an unknown quantity at this point
This info is wrong. The vehicle speed readout and shift points are based on tire diameter/circumference, not the wheel size. You can put any size wheels you want on (provided the clearance is there for brakes and suspension) as long as the overall tire size is the same as stock and the speedometers will be just as accurate.
Do the smaller wheel, taller sidewall. Your ride will be smoother and tires will be cheaper.
solman98 likes this.
Fediej is offline
post #5 of 12 (permalink) Old 01-28-2019, 12:43 PM Thread Starter
Quoted: 2 Post(s)
Thank you, I am really leaning towards smaller wheel and stock tire size for that wheel size but do not want to incur the extra cost if the benefits are negligible.
post #6 of 12 (permalink) Old 01-28-2019, 01:45 PM
solman98's Avatar
Drives 2014 Elantra Sport 2.0 6M 2016 Tucson Sport 1.6T
Quoted: 1001 Post(s)
solman98 is an unknown quantity at this point
This info is correct.
2014 Elantra Sport 2.0 6M Shimmering Silver. LED interior lights, cargo mat and net. 35/20% tint. LED tag and back up lights. LED fogs. LED headlights, homelink, 225/45R17 91V PureContacts.
2016 Tucson Sport 1.6T 7A Caribbean Blue. Hitch, tint, mudguards, homelink, cargo cover, LED back up and tag lights, power pass seat lumbar installed, LED fogs, aftermarket crossbars for the roof. LED direct fit headlights.
solman98 is offline
post #7 of 12 (permalink) Old 01-28-2019, 02:44 PM
xaran's Avatar
17 Sonata Sport 2.0 T, 07 H2, 95 Wrangler, 10 Mustang GT, 01 E 350 Van, 2011 HD FLTRX, 10 KX450, 08
Quoted: 251 Post(s)
xaran is an unknown quantity at this point
Im in a 2017 2.0T Sport, factory wheels and tires are 235/45/18 (overall diameter is about 26.3 "), I just replaced my tires at 50,000 and went up to 245/45/18 (increased overall diameter to 26.8) soi I ganed about 0.25" of sidewall.
On my car it corrected the slight speedo error from stock and I feel no difference in acceleration. Ride is a little better IMO dont feel grooves in freeway rtc. But that may also be due to tire choice.
As long as your overall diameter is below 27" and above 26.25" so there is no more than a 0.5" change it will not throw off the speedo enough to worry about. The added 0.25" of sidewall makes a difference IMO.
its a lot less money than new wheels and you still keep the sportier look. The Sonata with 16" and 17' wheels all are about 26.25 diameter tires
xaran is offline
post #8 of 12 (permalink) Old 01-28-2019, 03:19 PM
2011 Sonata 2.4GDI
Quoted: 767 Post(s)
deadrx7conv is an unknown quantity at this point
Dropping the rim size is a good start....find some 17" knock offs and use quality tires.
Sell your 18"s
Use the OE recommended tire size for 17's 215/55/17 or close enough diameter equivalent like 235/50-17
I went from 19's to 18's on my SUV and dont regret it. My Sonata runs 16" wheels and I wouldnt bling rim it on these graded roads.
Motto for advice giving on a forum: You can lead a horse to water, but you can't make it drink.
Sad country is where most neutered men can't change a tire or use a tire PSI gauge, can't check their engine oil or even pop their hood.
TrollBots are everywhere. Paid trolls are easy to spot in the 'off topic' forums everywhere.
Those who say it cannot be done, should not interrupt the person doing it.
deadrx7conv is offline
post #9 of 12 (permalink) Old 01-29-2019, 04:17 PM
2017 Tucson SE 2.0 FWD /w Pop Pkg
Quoted: 88 Post(s)
Circuitsmith is an unknown quantity at this point
I did this on my previous Toyota Matrix.
From 16" steel to 15" alloy.
Smoother, quieter ride. Each wheel weighed 9lb less.
"Don't let the same dog bite you twice."
- Chuck Berry
Circuitsmith is offline
post #10 of 12 (permalink) Old 02-01-2019, 09:20 PM
Matty_g91's Avatar
2011 2.0T sonata SE
Quoted: 25 Post(s)
Matty_g91 is an unknown quantity at this point
I’m currently in the same boat, I know all sizes and blah but what I’m curious about is how much if at all will it affect my handling and overall feel of the vehicle going from the low pro 18 down to a 17?
I tried going bigger sidewall on the 18s an it just made it feel to “floaty” an not really grippy An stiff, I’m sick of buying new tires due to potholes so I was thinking of 17s myself but don’t want to sacrifice overall look and handling
Matty_g91 is offline
