Brake replacement? - Hyundai Forums : Hyundai Forum
 4Likes
post #1 of 23 (permalink) Old 05-04-2018, 02:28 AM Thread Starter
2013 Sonata Hybrid Limited
Quoted: 8 Post(s)
kingaaron is an unknown quantity at this point
Brake replacement?
Has anyone replaced their brake pads and rotors?
Brake bleed procedure same as any other car? Anything to look out for with our hybrid?
Sent from my iPhone using Tapatalk
phftw likes this.
kingaaron is offline
post #2 of 23 (permalink) Old 05-04-2018, 06:45 AM
2016 HSH Limited Ultimate
Quoted: 104 Post(s)
NXR71 is an unknown quantity at this point
I have not yet but I am curious as to what mileage you're at. I've seen multiple reports of people saying they went 120,000 miles before the first brake replacement because of the regenerative braking.
NXR71 is offline
post #3 of 23 (permalink) Old 05-04-2018, 09:34 AM Thread Starter
Quoted: 8 Post(s)
81k and dont need to replace right this minute. Have about 25% life left on front pads. Just wanted to know if this is something we have to go to the stealership for or can we diy.
NXR71 likes this.
post #4 of 23 (permalink) Old 05-04-2018, 01:15 PM
Drives 2013 Hyundai Sonata GLS 2.4l, Drives 2014 Hyundai Santa Fe Sport 2.4l
Quoted: 76 Post(s)
kpanasew is an unknown quantity at this point
Did my front pads and rotors at 60k and will be doing rears this summer (price of living in DC). Fronts are easy/standard but rears you'll have to move the lower shock absorber bolt to get one of the mounting bolts out. Procedures below.
http://www.hsguide.net/rear_disc_bra...dures-391.html
If you've done brakes before, this will pretty much be the same procedure.
Sent from my SM-G930P using Tapatalk
kpanasew is offline
post #5 of 23 (permalink) Old 05-04-2018, 03:44 PM Thread Starter
Quoted: 8 Post(s)
Thanks a lot thats an awesome guide!
post #6 of 23 (permalink) Old 05-04-2018, 03:55 PM
2014 Hyundai SFS 2.0T 2016 Hyundai HSH Hybrid 2.0
Quoted: 386 Post(s)
MButkus
I don't think I have ever replaced rear rotors in any car, unless they were ruined by the pads. Front rotors go all the time. So the shock and strut only have to be removed if you have to get the rotors off in back, not the pads ?
I was wondering how long the pads would last, only 22K miles on mine. I'll check them in a few months.
MButkus is offline
post #7 of 23 (permalink) Old 05-04-2018, 08:45 PM Thread Starter
Quoted: 8 Post(s)
Thats how I read it, if only servicing rear pads no need to remove rear shocks.
post #8 of 23 (permalink) Old 05-04-2018, 08:50 PM
Quoted: 76 Post(s)
That's exactly why I'm replacing my rear discs. There are some deep grooves made by rocks and they're not worth putting on a lathe since the specs are already so tight and barely anyone does turning anymore.
If not changing rotors, make sure you bed them properly with the new pads.
kpanasew is offline
post #9 of 23 (permalink) Old 05-04-2018, 09:00 PM
Drives 2015 Elantra Sport Drives 2011 Sonata Hybrid Summer only 1985 GSL-SE RX-7 Summer only 1974
Quoted: 53 Post(s)
TimNH is an unknown quantity at this point
I just did the fronts on our 2011 Hybrid with 69K. The inner pad on both sides was half what the outer pads were. The left side rotor had deep groves from some type of contamination. The pads on both sides were pretty much stuck in place. So new rotors and ceramic pads and we are good to go. The backs were done at less than 50K. I think the backs work all the time while the fronts don't when reg is working. Braking is greatly improved. So don't rely on pad thickness but over all braking performance. When I checked the rears when I did the fronts, the left side was dragging already. So I cleaned up the pads, re-lubed them and the clip and seems fine now. These brakes need regular cleaning and lubrication.
TimNH is offline
post #10 of 23 (permalink) Old 05-04-2018, 10:33 PM Thread Starter
Quoted: 8 Post(s)
Did you go with oem or aftermarket?
