Engine issue 2002 2.7L GLS need advice I’m stumped. - Hyundai Forums : Hyundai Forum
post #1 of 8 (permalink) Old 05-12-2019, 09:24 PM Thread Starter
Drives 2002 Hyundai Santa Fe
Quoted: 2 Post(s)
Tcrow02 is an unknown quantity at this point
Engine wasn’t running good, low rpms. Exhaust was rusted out, so it was replaced.We also swapped out plugs, wires, tps, and the intake air controller sensor, because of the codes I was told my the guy at the repair shop. Started car and it revs very high for a min or so, then starts surging up & down. I checked to verify I reconnected all the hoses, rechecked bolts on the replaced sensors and cleaned the map sensor. Timing belt was changed 3 years ago about 20,000 on it.
Really appreciate any advice. Limited it how much money I can throw at the problem. My son is getting rides from friends at school to his job,
So I need to get his done.
Tcrow02 is offline
post #2 of 8 (permalink) Old 05-13-2019, 10:45 AM
grcauto's Avatar
Quoted: 1044 Post(s)
Originally Posted by Tcrow02 View Post
Engine wasnt running good, low rpms. Exhaust was rusted out, so it was replaced.We also swapped out plugs, wires, tps, and the intake air controller sensor, because of the codes I was told my the guy at the repair shop. Started car and it revs very high for a min or so, then starts surging up & down. I checked to verify I reconnected all the hoses, rechecked bolts on the replaced sensors and cleaned the map sensor. Timing belt was changed 3 years ago about 20,000 on it.
What codes do you have?
Best practices for requesting help:If you haven't done so fill in your vehicle info and profile page. At upper right corner under the search box click on user cp (it's your control panel)
This info will show up to the left under your user name and is very helpful.
BE SURE TO ADD YOUR LOCATION SO WE KNOW WHAT MARKET YOU ARE IN.
  • Be sure you are in the correct forum for your vehicle.
  • Do a search for your problem. A lot of stuff has been asked and answered.
  • Do not double post for the same problem.
  • Give the model year....Engine size...transmission type (auto or standard)
  • Take a single issue at a time. Posting multiple issues at once will get convoluted very quickly
  • VIN number can be very helpful
  • Vehicle history can be good. How many miles. If not bought new, how many have you put on it.
  • Describe the problem best you can. If a noise can you get a sound or video file
  • Tell us what has been done, if anything, thus far. If tests have been performed give actual results not OK or passed. If scanned for codes the actual code(s) not O2 sensor or MAF, Etc.
  • If the vehicle has been to a repair facility it would be nice if you could post a picture of that invoice/bill
  • If your vehicle is under warranty you should have the dealer check it out. If it's a problem they see many times they will generate a safety recall or TSB. This is how they know of the problem.
This information can save a lot of time and get you the answers you need much faster.
Thanks,
Welcome aboard.
grcauto is offline
post #3 of 8 (permalink) Old 05-13-2019, 12:59 PM
AUTOSPARK's Avatar
Quoted: 2366 Post(s)
Check that your throttle cable(s) are adjusted properly.
I've experienced surging idle on a 2.7 in the past when the cruise control cable was too tight and holding the throttle valve open.
AUTOSPARK is offline
post #4 of 8 (permalink) Old 05-13-2019, 02:38 PM
2007 Honda CR-V auto
Quoted: 841 Post(s)
Would check for vacuum leaks.
Well, that really was a guess
However, would do as Autospark says and check the Throttle, cables, TPS (sometimes a good spray of brake cleaner clears it up)
Good luck and please come back and let us know how it goes
avisitor is online now
post #5 of 8 (permalink) Old 05-17-2019, 09:08 AM
chris6414's Avatar
Drives a 2006 Hyundai Santa Fe Limited, 3.5 V6
Quoted: 33 Post(s)
chris6414 is an unknown quantity at this point
Anymore codes?
Idle Air Control Valve on throttle body could be the issue. At 190K, my daughters was carboned up pretty good and wouldn't idle well. Idles perfectly after a good cleaning with berrymans.
chris6414 is offline
post #6 of 8 (permalink) Old 05-17-2019, 02:59 PM Thread Starter
Quoted: 2 Post(s)
Follow up. Checked the cruise control & throttle cables, Both were fine. The idle air control valve & TPS sensor are new. Ran the codes and just this one showed. P0122 throttle pedal position sensor switch A circuit low.
Tcrow02 is offline
post #7 of 8 (permalink) Old 05-17-2019, 05:52 PM
AUTOSPARK's Avatar
Your engine doesn't have a throttle pedal sensor. The code will be referring to the TPS on the throttle body. Since you've already swapped the sensor that kinda suggests you have a wiring fault. Low signal voltage trouble codes are often a symptom of a sensor power supply issue.
post #8 of 8 (permalink) Old 05-23-2019, 10:13 AM
chris6414's Avatar
Quoted: 33 Post(s)
Or it could just be out of adjustment. They do adjust a tad. 200-800 mvolts is the range for the signal
